Hi!
I have been reading a lot on this forum about the clear vs. metal braces issue, and I think that the best is, as many of you suggested, to go with the kind of brackets my ortho manage the best.
He recommended to me the metal brackets over the clear ones, and I don't mind, since I am fully determined to start the treatment.
However he told me twice that the main disadvantage of the clear brackets is that they slow down the treatment. He explained to me that this was due to the bracket's way to hold the wire which wasn't very good.
I read over here that are some types of clear brackets that work fine, but maybe my ortho don't like to use them; or they might be very expensive over here, I don't know.
Anyway, he told me that later in treatment I could change the metal brackets for the ceramic ones, but right now he wanted to use full strength over my teeth.
What do you think? I should ask him about the clear braces again? They look really good on the pictures I've been seen so far.
Which are the clear braces that work best?
Thanks a lot!!!!
More questions about clear brackets
- jennielee81
I have Opals. They are self-ligating: NO LIGATURES!!
If you click on my link below, you can see pictures of my progress. My top (ceramic bracketed teeth) moved very quickly; basically in 11 weeks.
My lower (metal brackets) teeth have not moved as fast. I think it was more because of the wire than the brackets. Once they put in a rectangular wire, my bottom teeth straightened out in 24 hours! OUCH!
If you don't mind the metal, go with that! Your ortho knows best. My ortho recommended the Opals for adult patients (at an additional cost, of course...) and I am quite self contious
so I sent with the ceramics.
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Thanks! it is really helpful to have your points of view. I guess I will go on with the metal brackets. I have the option of changing them for the clear ones in the future...I will consider that just because I really like the way they look!
Drazda, looks like we were on the same situation. How do you feel about having the metal braces on? Any feelings of regret, or anything?
I know it will be a shock when I finally see how the braces look in my mouth, but I don't want to think then "oh my gosh, I should have asked for the clear brackets!!!!"![Sad :(](./images/smilies/icon_sad.gif)
