Flossing is so hard with braces... :(
Will
#1 Post by Will »
I want to buy a waterpick since it's so hard to floss with my braces...
Are waterpicks good for removing plaque? I tried flossing yesterday and my gums were bleeding, which isn't a good sign... :roll:
how do i floss with my braces?!? it wouuld take around 1 hour to do since i have expanders on both upper and bottom... :cry:
will a waterpick help remove plaque? :?:
Braces On: 11/1/05
Braces Off: ???
Betty Bat
hang in there!
#2 Post by Betty Bat »
I had a lot of trouble flossing initially, but it did get better. Many others have also reported problems. I haven't tried a WaterPik so I can't comment on how well it works. I found that the BridgeAid floss threaders and Oral-B satin floss worked the best for me.
On a lighter note, I'm sure that I could floss much better if I was more ambidextrous (boy, is there a difference between what I can do with my right hand and my leftt hand), had better eyesight (I have to wear my reading glasses while I'm flossing), and if I could just grow a third hand!
nvcarissa
#3 Post by nvcarissa »
Didn't your ortho give you a floss threader? That helps a lot. At first it does take a long time, but it does get better!
Braced 5/11/05, BSSO with advancement 6/21/06, Debanded: 8/1/07. Click on www for my braces story.
calley03
#4 Post by calley03 »
I get my braces on in a couple weeks and I found out today from my sister in law (who got hers off last month, and I am using the same ortho) that our ortho gives out a water pik, and a sonic care, plus all of the other little stuff. And I can go get all the wax I need. If ortho's give it out it must work pretty good I would think, i'll find out.
Impressions on 12/5/05
Full Braces(ceramic top, metal bottom) 12/19/05
Gable74
#5 Post by Gable74 »
butterfly
#6 Post by butterfly »
Give it 2 weeks and you WILL manage it in a tiny fraction of the time you need now! Flossing with braces is a specific skill you have to learn. It learning takes time.
The technique I found useful is the following: Bend the floss threader into a U shape und hook it under the archwire going from the gums side to the teeth side! This is even faster than superfloss.
Nov 2 05 braced, 1/1/07 debanded & got positioner
weird_wired
#7 Post by weird_wired »
Could someone explain exactly how a waterpik works and why it is special/different?
I visited the waterpik site, but it didn't really seem to explain.
