Hey everyone,
I am considering gettin ceramic braces after xmas and already booked my appointment to get my moulds done. However, i have heard some horror stories and was wondering if they are myths or if anyone has had experience of them.
1. Your teeth can decay underneath the bracket?
2. Your teeth become badly stained under the bracket and appear black when the braces come off?
3. The brackets wear grooves into your teeth?
Please help as these stories are putting me off gettin braces
I suppose all you mentioned could happen BUT you need to realize that 99% of the time everything goes fine. If you take care of your teeth during treatment you shouldn't have any problems. There are horror stories surrounding everything in life but you gotta live. Ignore the horror stories and listent to your ortho you will be fine.
the_bufster84 wrote: Hey everyone,
If you don't practice good oral hygiene, you will get decay AROUND the bracket. You can't get decay underneath the bracket because it is glued to the teeth.
Why would they turn black? This makes no sense.
The brackets are glued onto the surface of your teeth. Your teeth are very strong and hard. No grooves will be worn into them.
I've never heard of them being black when you remove them, if anything I would think that they protect them from decay.
I've heard of the teeth AROUND the bracket staining, but I'm thinking that if your teeth stain bad enough to be unfixable with a bleaching session, that you are beyond needing braces anyway.
