Has anyone been able to have crowns bracketed?
I am getting braced in January, and was told they could possibly use brackets on all of my teeth. From everything I've read here, it seems likely that the brackets won't adhere to my (molar) crowns.
I'm hoping it might be possible, but wondering if anyone actually has been able to do this? TIA.
Uppers placed 2/8/06--Inspire ICE ceramics
Lower (stainless) placed 2/23/06
Treatment time: 17 months (estimated was 12-18 months)
Debonded: July 11th, 2007
Next appointment: June 2008 for retainer & nightguard check
crowns
Hi Granola and Calley
I have 2 crowns that were bracketed. They were ok until they put on coil springs and elastics,then they started to pop. Had one replaced 3 times....
So, last Friday I got spacers, and this Friday bands are going on.
Good luck, and let us know how you make out
Moi
Moi
Hi Granola
I have a crown with just a bracket, and it's only a temporary crown. (Temporary crown permanently fixed due to insurance. Will get the permanent one after braces come off) The first time they put all my brackets on, they didn't use anything special on the crown. So when they put the wire in it just popped off. We then waited till my six week appointment and at that time he roughed up the surface so he could get a good bond, and I think used different glue. He was able to rough up the surface because it didn't matter since I was replacing it when I get the braces off anyway. So far so good, but it has only been about three weeks since it was put on.
Good luck! Maybe you too will be lucky enough not to have spacers and molar bands. At least you know that it is possible now.
Braced - 10/04/05
Treatment - 30 to 36 months
Ceramic uppers, Metal lowers
Impacted canines-Crowding-Crossbite
6 baby teeth!
Canine exposure surgery of two teeth 3/29/06
2nd canine exposure of one tooth 11/15/06
6 baby teeth!
I have 3 molars that are capped, and 2 have stuck with no problems whatsoever. The 3rd one has popped off about 4 times in the past couple of months. He finally had to rough up the outside of the cap a bit and reapply. So far so good. If this doesnt work, dont know what is next. I do have the Damon 3's, and like I said, no trouble on 2 of them(bottom), trouble with 1(upper). They do have to use a different bonding process to get them to stick.
Damon 3 brackets, upper and lower.
Braced 1/19/05.
Expected Treatment lenght: 2 years.
1 upper bicuspid extraction to occur 2/10/05.
Braced 1/19/05.
wow, you guys all sound lucky to me. My ortho wouldn't even consider putting just brackets on. I have two molar crowns, one top left one bottom right. He just said its bands or nothing. I askd him about it and he told me it would be less painful this way in the long run. The worst thing that I can tell about it is the stupid spacers were not fun at all.
It is better to aim for the stars and land in a tree than to aim for a tree and land in the mud.
Gel
My Ortho said that she will only do bands on the crowns. (I have three) I guess I didn't know that they did direct bonds to molars. So now I am wondering if she is going to do all bands on the molars or just the crowns..??
So I take it from all of this that the adhesive with a direct bond will not hold to a non enameled tooth.
