Lower front tooth was pulled! Now the gap is almost closed..
rangerchic
#1 Post by rangerchic »
But I have extra gum tissue! How will they get rid of it??
RC
Leslie022
#2 Post by Leslie022 »
They might refer you to a periodontal surgeon. I have a gap in between my front upper teeth. My ortho said I would need to have the extra tissue removed to keep my teeth from separating again.
Braced: Jan. 17, 2006
Removed: Oct. 26, 2006
Fixed bottom retainer
Clear Essix Retainer on top
altinure
#3 Post by altinure »
You shouldn't need to. What you just need to do is apply pressure to it and brush it a lot. It will reduce a lot. Don't worry about it bleeding. It worked for me.
Natasha_26
#4 Post by Natasha_26 »
Rangerchic,
How long did it take for the gap in your bottom teeth to close? I am curious coz my ortho also removed my lower incisor becoz of overcrowding and when I talk the gap show which bothers me a lot.
Upper and Lower Ceramics
rangerchic
Gap
#5 Post by rangerchic »
It took about 4 months to close!
RC
