Question: Should/Do you put wax on the spring?
Tunkabean
#1 Post by Tunkabean »
I went for my 1st adjustment today after getting braces just a week ago. The dentist put in a spring over my canine.
Question: Can/Should I wax the spring? Or will that stick between the coils and prevent the spring action from working properly?
Any thoughts on this?
jcdamon3
#2 Post by jcdamon3 »
Hi Tunkabean,
The spring is trying to move out so I don't think anything stuck in between will hurt. I had a spring and was lucky enough to not have it hurt my mouth. It was probably because mine was on the bottom though. Good luck!
Kell
#3 Post by Kell »
I have 3 springs on my lower teeth. I put wax on two of them. When I had the braces put on the assistant gave me tons of extra wax and said that I would need it because I have so many springs. I took that to mean that it was fine to put wax on them. I put mine just along the bottom edge of the spring.
Kelly
See my WWW link below.
Tunkabean
#4 Post by Tunkabean »
ah yes - the springs move outwards.... that makes sense! :idea: lol
Thanks for that.
I guess I'll be waxing away soon enough. Thanks guys :D
