Waxing Problems
Waxing Problems
My orthodonist gave me wax to use when my braces are irritating the inside of my cheeks, but I can't seem to get it to stick, or if I do it doesn't work well and I still feel it. I'm developing a sore spot on one of my cheeks, does anyone have any recommendations of what I can do?
Order some of the Braze Eze. It comes pretty quick and works like a dream.....so much better than wax! AND it stays on all day, even when you eat! Its a little spendy but really works!
Here is a link to the website.
http://www.udent.com/braceeze/index.html
Brandy
Brandy
Hi jennandtonic,
I was given two types of wax at my ortho's office. One was the standard wax and the other is called Brace Gard. Brace Gard is a Silicone Brace Wax. The first time I used it, I had a problem of it not sticking. Then, after reading the directions, it indicated the material and bracket must be dry. So, I just dried my hands and instead of drying off the area of my expander irritating my tongue, I just swallowed to get all of the saliva out of my mouth and then placed it on the area of the expander - it works very well. In fact, I think it feels better than the standard wax (it's softer). I hope this helps.
ssfw
ssfw
Braces removed: 8/19/08
Next appt.: 11/18/08
- jennielee81
Use a bigger glob of it. You need to use plenty!
Then use the inside of your cheek (push on the outside of your face with your finger) to stick it down smooth and tight. The saliva won't stick to the wax or silicone and that makes a nice smooth covering.
Warm salt water rinses and non sodium-laural-sulfate toothpast until that little sore heals.
