When Could You First See Your Teeth Had Moved?
It's only been 3 weeks since I've been braced (feels like 3 months). I can feel that my teeth have shifted based on changes in my bite and spacing differences when flossing, but visually nothing looks any different. I'm wondering how long it was before you could visually SEE that your teeth looked different. (I didn't need any extractions so that probably means it takes longer to see a difference).
You sound as bad as me. Bet you're always looking in the mirror to see if they have moved. I know I am! I too notice the little changes when flossing. I'm constantly peering in the mirror..this has to stop. I just want them to hurry up and move!
Upper metals on 10th Feb 2006
Estimated treatment time 9-12 months
I'm pretty much the same as you. I'm feeling the hange more than seeing them.
The two changes I've seen have come in the last two or three weeks, and they're both much more minor than I'd expected after seeing how "quickly" everyone elses pictures seem to come in their progress pics.
My bite has changed so that my top teeth no longer hit the bottom brackets in front, and my lower front teeth have straightened just a bit.
Nothing dramatic though at the month and a half mark, just continuing in the right direction slowly but surely.
Upper and lower metal braces
Estimated treatment time: 20 months
Same here. At first, I couldn't touch my molars together on the right side and now it's the opposite -- I can on the right but not on the left. And my top teeth are not hitting on my bottom braces quite as much as before. BUT I STILL CAN'T SEE ANY CHANGES!!! LOL!Anticipator wrote:I'm pretty much the same as you. I'm feeling the hange more than seeing them.
Samantha, I hope once things get well underway my teeth will move quickly like yours did!
I started noticing changes in the first few weeks. Small changes, like you said, when I flossed. I have had my top braces on for 3 months and they have moved alot. My top teeth used to hit my bottom teeth when I bit down and now they are not even close to hitting each other.
You won't notice the change as much as other people will, because you are looking in the mirror evey day and looking to see if they have moved. (If you are like me)
It's hard to be patient isn't it I know I am not patient at all, I want them to be straight right now
During Week 3
I was able to see (and feel) movement in my teeth during week 3 of having my braces. I had two teeth on my lower arch (right in front -- don't know the numbers) which were overlapping -- the front one was at a 30 degree or so angle in front of the adjacent one.
This was the first "hot spot" in my mouth that required wax -- I remember on Day 2 of being braced that I had to put wax in this area since the brackets were scraping my bottom lip. I soon got used ot this routine of wax in that area, and then about the third week of having braces, I didn't put wax on after brushing, and found that my braces were not irritating my bottom lip! Well, I look more closely and realized that the 2 teeth had realigned and were no longer overlapping!
That was a great motivator and reassurance that I had made the right decision to get braced.
Same here lol. I have no patients!! I was expecting changes the next day!!! I haven't really seen any changes and it's been a month...I do feel a change in bite thoughbrat 2 wrote:It's hard to be patient isn't it I know I am not patient at all, I want them to be straight right now
I guess through this experience I have had to develop some patience! I saw movement immediately because of a huge gap that had been powerchained! But after that not a lot of movement for a long time! I had to wait a whole 18 months just to get bottom braces!
Good luck in seeing some movement!
-Hannah
Top braces: 4/28/04
Bottom braces: 11/16/05
Last Adjustment was 2/1/06 where they bonded a bracket to my cuspid, which was impacted!!!! OUCH!
-Hannah
Top braces: 4/28/04
i saw movement within the first 10-14 days. i had SIGNIFICANT change in the first 5 weeks...basically my top teeth straightened out completely. my bottom teeth don't loook like they've moved at all in two weeks though.
four bicuspids removed 1/3/06
