I've had my braces for a few weeks now. As most of you know, they can ache and your teeth be a bit tender at first. However, that tenderness feeling passed in a week or so. Now I have this one tooth that very tender, it hurts to touch the tooth from the outside of my mouth.
Anyone experience this? I'm wondering if it's be cause my bite is changing. One thing I've noticed since getting braces is my teeth have moved and they now only meet in the front. The back don't meet at all. I'm wondering if this could possibly be causing that tooth to ache up front?
- Missing Tooth -
Tenderness
Tender Teeth
Hi missing_tooth,
After the general aches you usually get after just getting braces, I experienced isolated tenderness on single teeth throughout my first month. It wasn't that bad, but every once in a while one tooth would start aching for apparently no reason. It sometimes lasted a couple of days but would then go away.
I think the tenderness just means that your teeth are moving in some way. I think it's a good sign!
Maybe if it lasted a long time on just one tooth, it might be a cause for some concern, but I'd give it a chance to go away on its own.
Class II Malocclusion (Anterior Open Bite & Mild Crowding)
6 ceramic uppers, the rest metal
![Image](http://tickers.TickerFactory.com/ezt/d/4;10723;56/st/20060121/e/Braces+On%21/dt/13/k/5c1c/event.png)
I often feel some kind of tenderness or something in one tooth or another for either a day or so when I either brush me teeth, touch it or apply some kind of pressure to it...A few days ago, one of my tooth was a bit tender and today it's another tooth...
I am going for my 2nd adjustment in 2 weeks so I will ask but I am pretty sure that this is normal...
![Image](http://tickers.TickerFactory.com/ezt/d/4;10722;104/st/20070208/e/14th+adjustment/k/2f6d/event.png)
