Blood when you floss?
jennandtonic
#1 Post by jennandtonic »
Anyone else having this problem? I never used to get blood when I flossed before I had braces, now I'm getting a little bit each time. Is this normal?
Flora2006
#2 Post by Flora2006 »
It's normal to sometimes bleed a little...but if its on a lot of teeth and very often, I suggest you calling your dentist or ortho...could be a sign of early gum disease; gingivitis
noppi
#3 Post by noppi »
Lucyloop - what's OTT?
There's this one spot way in the back that tends to bleed for me. One time it was a lot...eek.
11/11/05~8 Spacers
11/21/05~Spacers off, 8 metal bands
01/13/06~Braces
04/13/06~4 extract
04/18/06~1st adjust after extract
Leslie022
#4 Post by Leslie022 »
My teeth are so tight, I have to use a lot of force just to get the floss between them. So, naturally, my gums bleed when they are basically sliced by the floss. :?
Braced: Jan. 17, 2006
Removed: Oct. 26, 2006
Fixed bottom retainer
Clear Essix Retainer on top
jennandtonic
#5 Post by jennandtonic »
I spoke with my orthodontist today and she said there is nothing to worry about, and checked me out and said I have an 'A' in the cleaning department. She said it was probably just overzealous flossing. Thank you for all your suggestions, looks like my cleaning is sometimes OTT, too! :D
DizzyKitty
#6 Post by DizzyKitty »
I have a couple spots that bleed where I have to slice it in there too.
- Dizzy
WiredNana
#7 Post by WiredNana »
I don't have the bleeding...but my teeth sure do ache after flossing!
Plus...they feel like they have moved...can this happen after just 4 days from being braced?
bracesmom
#8 Post by bracesmom »
Yes, I understand. I posted (perhaps in the wrong place) a similar concern
I am pretty routine in my flossing and brushing habbits.
I floss more often now than I did before braces. Did you ever notice your gums were more sensitive to flossing after you had braces on?? My gums are actually bleeding at times which I didn't have a problem with before. Is it because my gums are more sensitive with the movement of my teeth? I am wondering what the deal is...
Perhaps I am just "OTT" :wink: too with my flossing now...? I wonder....
