Different Sized Wires
PnkPrincess024
#1 Post by PnkPrincess024 »
Why does the ortho change the size of the wires from thinner to thicker...does that mean ur teeth are moving and you need a stronger one or what???
BraceUrself
#2 Post by BraceUrself »
Getting thicker or larger wires is GOOD news! You have made progress & are moving to a new stage of your teeth movement! Congrats!
Spacers-9-19-05
Top Braced-10-03-05
lowers on-10-17-05
appliance installed in mouth 10-17-05
2 extractions on 8-3-06
2 years treatment time
Dr says I won't finish on time
PnkPrincess024
#3 Post by PnkPrincess024 »
i just got my first adjustment on my bottom teeth and he went from this thin wire to a little thicker one...you know the kind he gives you when you first get your uppers on. so far ive had my uppers since sept 2005 and lowers since late january 2006. my ortho has kept me on the same wire for my top teeth for 3 months in a row now but its the really thick kind, so does that mean they arnt moving???
PnkPrincess024
#4 Post by PnkPrincess024 »
now im wondering what phase im at...i guess phase one because ive only had one adjustment on bottom and five on top.
Nikkiekoala
#5 Post by Nikkiekoala »
Wow that is a great site! I am in the final phase of phase one. At my next adjustment they are going to start leveling. That will include elastics.
Braced Aug. 11th 2005
Damon 3's
Crowding
Crossbite
**My Website: http://nikkiekoala.efx2blogs.com/
PnkPrincess024
#6 Post by PnkPrincess024 »
how do you know what stage you are on??? and what part of the stage you are on???
PnkPrincess024
#7 Post by PnkPrincess024 »
Nikkiekoala
#8 Post by Nikkiekoala »
My Ortho told me at my last adjustment. He said that the wires he put in will finish up getting all my teeth aligned and that next time I come in he will start leveling and will need to start using elastics. I will also have my wire changed again. Just ask your ortho he will tell you.
Damon 3's
Crowding
Crossbite
PnkPrincess024
#9 Post by PnkPrincess024 »
when they mean aligned, does it mean that all the gaps are closed
Nikkiekoala
#10 Post by Nikkiekoala »
According to the site that KK gave not necessarily. I have one gap still but my ortho doesn't plan on closing it until later.
Damon 3's
Crowding
Crossbite
PnkPrincess024
#11 Post by PnkPrincess024 »
i read that site adn it was kinda confusing. could someone put it in simpler terms what each phase is please???
Attagirl2
#12 Post by Attagirl2 »
Hi, maybe this site will help you....
http://www.unc.edu/depts/appl_sci/ortho ... t/one.html
