Toothpaste whitening with braces
Lin
#1 Post by Lin »
Does anybody know whether it is wise or not to use a whitening toothpaste while braces are still on? Or will it make the color of my teeth uneven once the braces come off (like under where the brackets were, where whitening toothpaste can't touch with braces)?
Any tips for things to do or not to do while braces are on to avoid staining and marks once the braces come off?
-- Lin | Braced on 1/31/06 | 5 extractions + Canine Exposed 4/19/06
genxsis
#2 Post by genxsis »
I've been told it's a bad idea for the very reason you gave. The whitening form the toothpaste cannot affect the area of your teeth under the brackets, so when they come off, the whitening will be uneven.
eoberhauser
#3 Post by eoberhauser »
My orthodontist said it is absolutely no problem. My boyfriend who had braces when he was in his early teens said his teeth were actually whiter where his brackets were when he got them off. I think it's a call for your orthodontist to make.
Harpua
From what I've heard
#4 Post by Harpua »
At least form what I've heard, whitening toothpaste don't really do a whole lot of whitening as they whitening agent doesn't spend enough time in contact with the tooth. They are however, much more useful, for maintaining tooth whitening. I think it shouldn't make much difference, other than maybe keeping your teeth from staining, which would be a good thing. And my orthos opinion was that whitening toothpaste is fine.
Flora2006
Re: From what I've heard
#5 Post by Flora2006 »
Harpua wrote:At least form what I've heard, whitening toothpaste don't really do a whole lot of whitening as they whitening agent doesn't spend enough time in contact with the tooth. They are however, much more useful, for maintaining tooth whitening. I think it shouldn't make much difference, other than maybe keeping your teeth from staining, which would be a good thing. And my orthos opinion was that whitening toothpaste is fine.
I agree.
I still won't use whitening paste JUST in case but whitening paste doesn't really whiten in the first place...
Leslie022
#6 Post by Leslie022 »
My ortho told me to stop using whitening toothpastes while I have the braces on. I've noticed a big change in the color of my teeth, too. I don't go by advice completely...I use whitening toothpastes 1 or 2 a month just to keep my teeth from staining really bad. I'm a coffee drinker, so...
Leslie
Braced: Jan. 17, 2006
Removed: Oct. 26, 2006
Fixed bottom retainer
Clear Essix Retainer on top
Evelyn
#7 Post by Evelyn »
I think regular toothpaste with whitening should be fine but just be careful when it comes to the more expensive ones that promise a stronger whitening. I don't think they would make a difference, but better safe than sorry
Eve
Braced September 9, 2002
Debanding: JULY 5!!!!!!!!
KJM
#8 Post by KJM »
I use a whitening toothpaste (Crest baking soda and peryoxide) and my ortho said it was ok. I also use Remembrant Intense Stain to remove any coffee stains ( it is expencive but works well)
My dentist recommended I use Listerine Whitening mouthwash as well, but I am going to ask the ortho before doing that.
~*~ Kim ~*~
Next Appointment #14: Feb 26,2007
rsprouse
#9 Post by rsprouse »
Whitening toothpaste's have no active ingredient for whitening which is usually a peroxide (carbamide, hydrogen, etc). They are called whitening because they have a mild abbrasive that is more aggressive at removing stain than a normal toothpaste. Baking soda is a popular ingredient. It will give you similar "whitening" results as if you got your teeth professionally cleaned at the dentist. That being said, if you eat or drink a lot of things that will stain your teeth (if it stains a white shirt it will stain your teeth) then you may benefit a little from a whitening toothpaste. But brushing with a product will not result in having dark spots where you brackets are/were when they are removed. Just stick to whatever toothpaste you like.
Lin
#10 Post by Lin »
It sounds like whitening toothpaste is probably okay to use. I will ask my ortho at my next adjustment anyway, but I suspect that if using it really could leave marks after the braces are removed, there would be more warnings from orthos about that... because I really love my whitening toothpaste!
Thanks, everybody!
stargirl
#11 Post by stargirl »
I used whitening toothpaste before braces, and I still use the same kind now. A couple weeks ago at my last adjustment, I had a few brackets taken off, and there was no difference between the part under the bracket and the normally exposed tooth... 10 months later, after only using whitening toothpaste.
I had too thought that whitening toothpaste could make it look all blotchy, and I was relieved to see that it all looked a nice uniform colour.
