WHAT IM I DOING WROUNG???
OK SO I GO GET A TICKER AND I PASTE THE CODE IN TH SIG SECTION AND YOU SEES WHAT SHOW UP NOT THE TICKER..ANY SUGGESTIONS
THANKS MATEO'S
You also need to make sure that in the settings area (where all those check boxes are) you have selected "Yes" for the one that talks about allowing BBC Code.... also wouldn't hurt to make sure you have selected "Yes" for allowing HTML.
Can you do me a favor? On the internet when you write in all caps IT MEANS YOU ARE YELLING... and it's also incredibly hard to read. Can you please not type in all caps? use all lower case if necessary, but it would be a lot easier to read/respond to your posts if they aren't in all caps.
Thank you!
Thank you!
It's a two year process.......
