question that's probably never been asked about powerchains!
i got my powerchain on in feburary- the 17th or something i think. i got it to close up this big ugly gap i had between my front teeth and just a couple tiny tiny gaps. i think it makes my teeth look way straighter and since i've got clear braces, it covers the wire and makes it barely look like i have braces at all! that said, i love this powerchain haha. i am hoping they leave it on for at least a couple more months. how long do people usually wear them for? i really don't want to get it off at my appointment coming up, but all the gaps are already gone. this is probably strange for somebody to actually WANT to keep it on. does this mean i'm close to getting my braces off at all on the top? since they're already fixing the details??
I'm going to have braces forever :[
I started with powerchains last summer, and I agree they close everything up and make your teeth look great. It is now March, and I still have powerchains. At each adjustment the ortho shifts them to close another gap that was created by closing the previous gap...and so on and so on. Feels like it will never end. I go back Tuesday...and I am sure they will put on another powerchain.
Good thing you like them, you will have them for awhile!
Gardnr
Gardnr
For the first couple of appts in the beginnning, I had a powerchain across my two front teeth to close a huge gap! After it pretty much closed they took it off!
After getting lower braces, I had powerchains for about 4 months to close extraction gaps! Then, this last adjustment, he wanted just normal ligs on the lowers. He gave me a new humongo wire which is helping to close the gaps to the side of the extraction gaps created by the powerchains! Confusing, I know! For me the powerchains on the bottom actually created more gaps than closed!
~Hannah
Top braces: 4/28/04
Bottom braces: 11/16/05
Last Adjustment: February 28, 2006 where they gave me a new bottom wire and attached my impacted canine, newly bracketed, to the wire! OUCH!
~Hannah
Top braces: 4/28/04
I've had powerchains for a year now on my upper arch and two months on my lower arch. I was told at my next adjustment I'd be getting my "finishing wires" which got me all excited...until I heard that it's still going to be another 6-8 months. So much for a braces free summer.
Mike
3M smartclips top and bottom since 10/13/04
Off November 06!
Off November 06!
about 3rd month into treatment i got a powerchain on my uppers, but it was only just for one month, then my orth just put the regular bands on again except for the past 2 months ive had the same thick wire (if someone can explain what is the purpose of the thick wire is thanks). im just waiting till he puts the powerchain of my bottom, which ive only had since late january, because my lower has soooo many gaps, plus it seems as though the left side teeth are longer than the right side. to make it even is that what the rubber bands are for??? my ortho said something at my last appt about i will need rubber bands but he didnt say when. does it usualy go with closing gaps and then using the rubber bands or what???
