Poll: First Adjustment
Leslie022
#1 Post by Leslie022 »
At your first adjustment, how much work was done? Did you get new wires, elastics, powerchains, etc.
Braced: Jan. 17, 2006
Removed: Oct. 26, 2006
Fixed bottom retainer
Clear Essix Retainer on top
OneTime
#2 Post by OneTime »
For my first adjustment I was place with new wired and ligs. I was in for 15 minutes for the process then I was on my way with an appointment for a second adjustment. Six weeks later.
In process...
4 spacer and upper braced 1/10
Spacer removed and fully braced 1/24
Final 05/15/08
Flora2006
#3 Post by Flora2006 »
At my first adjustment which was 4 weeks after getting braced, I had my ligs changed and my canine that is in a crossbite position got a lig AND a tie wire...the ends of the wire were also cut.
I am having my 2nd adjustment tomorrow and I'm really hoping for something more than just a lig change...
jcdamon3
#4 Post by jcdamon3 »
Gosh you know what? I can't remember! I think they replaced one of my wires and adjusted my spring! Scary that I can't remember and good in a way. Hopefully soon all this will become a dim memory.
They haven't replace any wires in my mouth now for like 3 months. It will be 4 1/2 months with no wire replacement by the time I have my next adjustment in April. They did reposition brackets though.
Mid Forties!
mtbrncofn
#5 Post by mtbrncofn »
My first one was also 6 weeks after I got braced. All I got were new ligs.
KJM
#6 Post by KJM »
My first adjustment was 6 weeks after being braced.
They changed the ligs, and my wayward tooth was hooked with a lig on 3 sides of the bracket (instead of the 2 that was previously on)
~*~ Kim ~*~
Next Appointment #14: Feb 26,2007
Anticipator
#7 Post by Anticipator »
Six weeks for me as well. Ligs were changed top and bottom and lower teeth had interproximal reduction (shaved) between certain contact points.
I'm hoping for something more radical at my second adjustment.
Upper and lower metal braces
Estimated treatment time: 20 months
Shawnie
#8 Post by Shawnie »
My first adjustment was six weeks after being braced. They changed my wire and put on new ligs. Also at this time they put the archwire through to all the molars.
They put back on the same springs that are over my two baby teeth making room for my impacted canines when they come down.
Braced - 10/04/05
Treatment - 30 to 36 months
Ceramic uppers, Metal lowers
Impacted canines-Crowding-Crossbite
6 baby teeth!
Canine exposure surgery of two teeth 3/29/06
2nd canine exposure of one tooth 11/15/06
Kell
#9 Post by Kell »
I just had my 1st adjustment last week. It was after 6 weeks. The ligs were changed. They took off ligs and put on wire ties on all the top front teeth. They added a spring on the top to push some teeth apart so they can straighten out. The wire was not changed.
It was a quick appointment and my teeth weren't too sore after.
Kelly
See my WWW link below.
alexa
#10 Post by alexa »
I had my first adjustment four weeks after being braced. I got new ligatures and elastics.
Spacers: 1/26/05; 2/6/06; 3/15/06; 4/24/06
4 First Bicuspids removed: 2/2005
Metal Braces, top and bottom: 3/1/05; Debanded 7/26/07
Hawley retainers top and bottom
Shelby014
#11 Post by Shelby014 »
At my first adjustment i got both top and bottom wire changed to heavy duty rectangular heat activated wires, and i got all my ligs changed.
O.o*Shelby*o.O
braced on:9-29-05
http://tickers.TickerFactory.com/ezt/d/ ... /event.png[/img]
MyTinGrin
#12 Post by MyTinGrin »
At my first adjustment, i had a couple of brackets repositioned, and got a new top wire.
Evelyn
#13 Post by Evelyn »
I got new ligs (purple and orange, highly recommended btw a fabulous and fun color combination) and then I think a new wire, and then a criss-crossy very thin wire in figure 8's around my front four teeth, and it's been there ever since.
Braced September 9, 2002
Debanding: JULY 5!!!!!!!!
bracesmom
#14 Post by bracesmom »
My first adjustment was 9 weeks after being braced. I got a new wire (thicker) some metal ties, new ligs and power chain over my front top four teeth and my palatal expander bent upward to fit better.
