This is my third lefort and second bsso. Surgery was a bear because of many complications from previous surgeries that I'm not really comfortable going in to here, but whatever, surgeons are happy and hopefully this is the last one I have to ever do. Surgery done by Arnett and Gunson in Santa Barbara, CA. Can't say enough good things about them. If they can fix my mess than they can fix about anyone.
Cool things to see is that you can see where they took the punches for the bone graft out of my one cheek. The other cheek ended up having some problems with the bone and that ended up having to be grafted instead of being used for the graft. You can also see the graft material in the bsso fill. They also spackled the old waisting in my jaw from the previous surgeries, so that will be cool to lose that. The screw under my upper lip and the hook under my lower lip are for attaching bands and are seriously annoying. They'll be removed eventually. Yay for science!
Before:
![Image](http://i43.tinypic.com/mc4xlt.jpg)
After:
![Image](http://i41.tinypic.com/14kvwm.jpg)
