exercise after surgery
Hi freerideuk and Clover
Which surgeon are you with at the SGH? I'm with Mr Koppel and I think I've met a Mr Devlin are there any others?
I've actually had about 4 planning apointments sofar and all I'm sure of is that my top jaw is being moved up 4-5mm and possibly out 1-2mm
I have an open/overbite, I got from previous jaw surgery. They may also do my bottom jaw as well, it depends on how well things line up with the braces. My next appt. is the 12th of Feb so hopefully I will at last find out whats happening!
Good luck all
Good luck all
My surgeon said exercise light exercise (walking, etc) is fine almost immediately, and heavier exercise is okay after two or three weeks as long as there is no risk of impact to your face or any excess jaw pressure (i.e. avoid any heavy weight lifting where you may clench your jaw).
I did specifically ask about snowboarding, and he said that if my surgery was in fall or winter I probalby wouldn't have much of a season, if any at all. There is a very high risk of facial impact in snowboarding, and one minor tumble with you landing the wrong way could basically destroy your face (remember, your jaw is basically being held together by a few pins). Even landing hard on your butt when catching your heelside edge could cause you to bump your jaws together hard enough to do some serious damage. I believe he recommended at least 4 months of letting you bones heal before taking the chance with impact sports.
Not the news you wanted to hear, but that's what my surgeon told me. You may want to double check with yours, as different surgeons have different recommendations for recovery.
i am quite upset harding 4 whole months of no boarding
but i expected as such
it will be soo depressiong not boarding for third of a year
but in the end i will still be able to board and my face will be all better =]
all manage to wait itout
and i will check and see what he says it will probs be the same amount of time he says
xxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxx
yes, this is def. one of the frustrations. check with your surgeon though for sure, there is such variability.
i actually will begin doing some more moderate exercise starting on Saturday as i just can't stay put any longer. won't do plyometrics or anything so that i don't jar my jaw too much. but will def. be picking it up.
good luck and fingers crossed that you will be able to do more than you expected.
thanks kballing
am sure i would be able to get gradually bk into it before too much just nothing too extreme
i should be able to take lessons fine before then i think
cause there is little chance of me falling
as you teach the basics
but i shall doo what the doctor says lolz he knows best not me =]
and kballing don't get up too to much don't want to risk the out come of your new bite =]
xxxxxxxxxxx
xxxxxxxxxxx
hey,
i had sarpe surgery about a month ago. I thought i would have to take a month off the gym, but i started hittin the gym about a week and a half later. First few weight sessions were easy as i felt tired and weak, but a month later im feeling about 95%. I never asked anyone, just went by how i felt, dont think ive done any damage....
