First, I already had four premolars out as a kid, so after losing the wisdom teeth I won't have many left! Since one of the reasons for my surgery is that the open bite was causing wear and tear on my back teeth, surely removing the wisdom teeth will put even more wear and tear on the ones that are left?
Second, I'm freaking out about the whole issue. Having my wisdoms out in two days makes the 'big' surgery feel more inevitable and I feel like I'm running out of any chance to escape from major surgery. When I made the decision to go ahead with treatment and had the braces fitted, the surgery seemed like such a distant issue I just ignored it. I got good at putting it out of my mind and just concentrating on getting adjustments and feeling my teeth gradually get closer together. Now that the reality's drawing nearer there's a huge part of me that just wants to pull out. My teeth are straight now, the bite is a bit better though I still have a 3mm gap and crossbite and I think maybe the lip incompetence will improve once I don't have to stretch my lips over two rows of metal. Then I catch sight of my hideous reflection and see the sunken cheeks, the constant 'sad' expression because my face is dragged down with excess vertical height, the droopy gormless mouth and big puckered chin and think that I'm just wimping out of surgery when I should be ecstatic that there is a way to fix my problems. But it seems as though all the pro-surgery thoughts are based on aesthetics, because even though my bite is still open I could easily live with it if I thought my appearance was attractive.
My husband says I'm trying to counter my fear of a couple of weeks of pain against a lifetime of misery about my looks and the functionality of my teeth has become a side issue. He's completely right, and I also worry about whether I will suffer TMJ, headaches etc in the future if I don't go ahead, but right now I'm totally stressed out and confused. Does everyone else have this ongoing fight in their heads about what to do, or did you all just know you wanted surgery and got on with it. I'm going so mad thinking about this and obsessing about it I really need some opinions from people who've gone through it. Thank you all so much![/quote]
Wow - Just stumbled over this thread, sounds very much like the way I'm thinking at the moment as well, need to have wisdoms out very soon plus some pre-molars, not done yet but once done then I guess thats it - away we go! I'll keep an eye on your prgress "keeponsmiling"
