Has anyone had inflamation around the screws?
mel
#1 Post by mel »
I am 9 weeks out from lower jaw surgery and genio and still pretty swollen on the right side. During the last couple of days I've had pain on that side with more swelling. (I am finally getting some feeling back) Saw my OS this morning and in the xray saw some inflamation at the base of all three screws. He put me on antibiotics and said that if I didn't improve he would probably have to go in and remove the screws. :cry: Has this happened to anyone else?? :o :o
science teacher
screws
#2 Post by science teacher »
I can't address the issue but I can tell you I am sorry you are experiencing this.
Here's hoping the antibiotics do the trick and you are better in no time.
KIM
SARPE 11/23/06
Expansion over 12/18/06 8.5mm
Brace day tops 1/15/07
Brace day bottoms 3/19/07
all expansion devices removed 9/19/07
nvcarissa
#3 Post by nvcarissa »
At my last visit to my OS, he checked my gums to make sure the screws were not protruding through. They weren't but he told me that if they were, he'd have to remove them. At that point I was three months post op and my bone had healed at about 90% and removing the screws would not have been a problem.
So, even if your OS has to remove your screws, it will probably be okay.
Hopefully the antibiotics will have their desired effect.
Braced 5/11/05, BSSO with advancement 6/21/06, Debanded: 8/1/07. Click on www for my braces story.
Brandyleigh35
#4 Post by Brandyleigh35 »
Yes this does happen. Check out Larkin's blog, sounds like she may be in the exact same boat as you.
http://crazyjaw.blogspot.com/
Brandy
mel
HAVING SCREWS REMOVED
#5 Post by mel »
Thank you to everyone who replied--I took one round of antibiotics and the swelling and pain subsided. Saw my OS on Friday and he says that I still have swelling and the dark areas at the base of the screws are still there. I'm scheduled to have the screws taken out this Friday--Ugh! :cry: He told me that it isn't a bad surgery--like having a wisdom tooth cut out :( . He offered either and IV or shots with gas and I chose the shots with gas to avoid the preparation (no food/water for 6 hours) since the surgery is at 3:00 in the afternoon. Hopefully this will resolve the problem. :D
Lark
#6 Post by Lark »
Well....it sounds like we are definitely having the same problem! Good luck with having them removed. :) I'll most likely be having mine taken out at 10 weeks post op.
I'd rather go through having them taken out...than being in constant pain for any longer than I have to.
mel
#7 Post by mel »
Well, countdown to tomorrow---I'm going to be a "big girl" and try not to be too nervous :roll: Will let you know on Saturday, Larkin, how things go since it seems you are facing the same ordeal!
Thanks again to everyone for the good thoughts :)
