Wisdom teeth and braces
Yep definately. I had 3 of mine taken out during my jaw surgery, and the other one taken out nearly 3 weeks ago. I dont think the braces make any diference to the removal, and its a matter of the surgeons preference.
![Image](http://tickers.TickerFactory.com/ezt/d/4;33;60/st/20080211/e/Jaw+surgery/dt/5/k/7e94/event.png)
We sure can! Only one little tiny issue with the braces! When you have teeth out, you have gauze in your mouth to help control/stop the bleeding. The gauze gets really tangled and caught in all the brackets and wires. Its a problem that you can deal with, but its still a pain in the butt! ![wink :wink:](./images/smilies/wink.gif)
~ Luella ~
Oral surgery assistant, Registered Dental Assistant, OMAAP Certified
