To Graft or Not to GRAFT - What is the answer....
I am receiving conflicting opinions (what else is new ) about grafting. Is it always necessary? What this latest OS is proposing is a segmented ( 3 piece) LeFort. He says he does not use grafting but will use her own bone in the area in which they cut. Was wondering what others had been advised. In my DD case this would be for upper - forward and up, lower forward.
I suspect bone grafts are related to 1) surface area between moved areas, IE if moving too far forward and need a larger base than the existing bone provides and 2) age at surgery, IE concerns about growth time?
I had a three piece Lefort, no bone graft, and they moved my upper forward 6 mm. They moved the upper front section down a bit too, not up.
I had one MINOR complication (hehe I say minor now that it all turned out well, but I admit I freaked out majorly at the time) - there was a hole in the upper palate between my sinus cavity and mouth, right where the three pieces of the lefort were sectioned and met. You can read about my freakout here: viewtopic.php?p=231879&highlight=#231879
Other than that, no complications. My OS was able to patch up the hole with a plastic shield he added to my splint - it allowed the hole to heal on its own, no problems. Mind, I'm honestly not sure how much of the issue was the lefort process or the complicated nasal stuff that was done on top of the lefort (I had an extremely deviated septum and they had to redo inside and outside of sinuses/nose to correct it, along with turbinectomy, and full rhinoplasty to comp for septum corrections being so drastic).
I've had no teeth complications; probably shouldn't compare sinuses since I had so much sinus work done on top of the lefort, but even then I've had nothing out of the ordinary. Feeling came back from rear molars forward, started with inside of mouth and in last months or so have gotten most if not all of the outside of upper jaw gum feeling back - anything not back yet, I can't even tell is missing.
I suspect that just doing a lefort is a lot easier than doing septo too at the same time, as since then I've read all these boards about septo and people just being knocked on their butts like nothing else for a week or so, which sounded about right
What I understand about the use of bone grafting is, that if the gap between the segments is larger than 5mm, bone grafting is called for. This is probably most often occurring in inferior repositioning of the maxilla, although defects in bone contact can occur with movement in any direction.
Remember, I'm not a professional--ask your surgeon!!!
There are no ordinary moments.
Check out my blog! http://pcadams.wordpress.com/
I had a 3-piece Lefort done on Feb. 19th. Doc said he wouldn't know if he would have to do a graft until he got into the surgery.
He was pretty sure he wouldn't need to, but wouldn't rule it out.
It turned out that he didn't need to do the graft. Which was weird because he also said they widened my upper jaw as much as they possibly could.
It was widened and moved forward.
I'm 10-weeks post surgery today and I feel great.
Interesting Phil!! I had 6 mm forward, around 1.5 mm expansion, no bone graft. It's the gap though, not how far forward, that you're referring to, correct? IE he could move my upper 6 mm forward, but b/c the bone shape/density whatever there could be less than 5 mm space between skull and palate segments.
From what my surgeon said, I think he would have added lower into the mix rather than bring the upper so far forward as to warrant a bone graft, for stability purposes. The man is also a completely anal perfectionist, which is good I suppose for someone redoing your face
Arvensis,
That's right, gap BETWEEN segments.
Meryaten,
I take that as high praise!
