hey i need some help,
on the 14 i'm going to remove 3 of my Wisdom teeth ...i'm not usually a chiken but i'm scared huh....
i'm doin that cause i'm going to have ibraces upper and lower in 4-6 weeks .
how long is the surgery takes?
what about recovery time?
my surgery is at 9 a.m,but one of my good friends is coming at 10 p.m from DC to visit me ...will i able to pick him up at the same day and we were planning to go to Grand canyon on the next day...shoud i cancel trip to Canyon?
Thank you for your help
Wisdom teeth will b removed on the 14
are they impacted ?
i had to have my impacted wisdom teeth removed under GA it wasnt that bad but was swollen for about 5 days lol
The worse part for me was not being able to eat
wisdom teeth removed under GA nov07 * Braced 8/2/08 * 2 premolars removed Apr08 * Adjustment 4 rebonding, 4 molar bands & new wire 4/7/08 * 31Jul wire change * 28 Aug last wire fitted and lower powerchain put on. 29th May moulds and x rays. 31st July Surgery date
wisdom teeth
hey,
when i had my wisdom teeth removed i was under GA. and after i took vicodin for like 6 days, therefore wasnt able to drive. and you could prolly go on the trip if some drives or whatever but you might not feel up to it bc you'll be swallon and druged up, and you;ll prolly be tired. these were my symptoms, maybe ask your doctor what he thinks.good luck, you'll be fine, i had no pain, ( except for the time i forgot to take my pain meds, so remember to take those right when your due to )
- Folk Ballad
I'm getting my wisdom teeth out this Monday and when I asked how long it would take to recover, I was given this analogy/example:
Say you have your extractions Friday, you should be able to return to work on Monday.
So it sounds like recovery time shouldn't be *too* bad. As for a trip to the grand canyon the next day, maybe you should just play it by ear and see how you feel tht day?
i also had 7 teeth removed today. i only have 3 wisdom teeth. anyways, most people i know took it easy the first day. personally, i have very little pain, but swelling is horrible. it took them 50 minutes to do everything.
i would try to take it easy the first few days and minimal physical activity.
