Did my Ortho ruin my midline?
Locked
Winter2009
#1 Post by Winter2009 »
Recently I noticed that my two front teeth and midline of my mouth don't meet like they used to be? Is this something I need to be concerned about? I will be having BSSO surgery......
before and after pictures
http://i646.photobucket.com/albums/uu18 ... efore1.jpg
http://i646.photobucket.com/albums/uu18 ... aa/Now.jpg
Does this happen to anyone here?
metoometoo
#2 Post by metoometoo »
My formerly perfect midline was shifted by the ortho pre-surgery also. Apparently it wasn't perfectly lined up on my face. Now, post-surgery everything is lined up nicely again. I wouldn't worry about it.
Folk Ballad
#3 Post by Folk Ballad »
My midline was already off before I had surgery, so perhaps I'm not the best person to comment on this. However, I'm under the impression that one's bite gets worse before they have surgery?
And I assume that your midline will be perfect or very near it after surgery because your surgeon will be lining everything up surgically? (My midline is pretty much dead on now.) Hope that helps in some small way.
changes09
#4 Post by changes09 »
My oral surgeon says that if my ortho can't line up my mide line (upper jaw) then its okay becuase he will fix it when he does the surgery. I'm not sure if this is the case for everyone or not.....
i'll have to post pics of my midline...its WAY off.
samoorelaw
Re:
#5 Post by samoorelaw »
changes09 wrote:My oral surgeon says that if my ortho can't line up my mide line (upper jaw) then its okay becuase he will fix it when he does the surgery. I'm not sure if this is the case for everyone or not.....
This is absolutely true, because my midline was way off prior to my surgery and was PERFECT after surgery.
Braces removed for 3rd and final time July 14, 2016!!!!
Permanent 8 crowns front 8 teeth (upper) January 30, 2015
Braces removed again December 3, 2014!!
Partial braces re-installation September 25, 2014
Braces removed September 4, 2014!
Locked
