Weight Loss
Weight Loss
What's the total amount of weight did you lose after this procedure? Were you wired/not wired shut?
Not wired shut either-just banded.
I lost about 20 lbs but I knew I would because of my frame and metabolism. So about 6 months before I thought I might be having surgery, I started to try to gain weight. I gained 15 lbs but it came off fast afterwards.
October 8, 2008 Lefort1(6mm impaction), BSSO, Genioplasty, Turbinectomies, Partial septoplasty, gum recontoring
- Folk Ballad
I let myself pack on a few extra pounds before surgery, because I lose a couple pounds just when I have an orthodontic adjustment so I knew I'd lose some significant weight after surgery. I wasn't wired shut, but I was heavily banded for about a week and a half.
I lost 10lbs or so and have since gained back 3lbs (which is actually where I want to stay since I'm at my ideal weight now. thanks jaw surgery!).
I was not wired shut, but heavily banded for the first 2 weeks and I lots about 9 pounds but once I was able to eat a bit more and take the elastics off I gained it back prety quick. Just try to get in as much calories as you possibly can and use protein powder!!
Braced: March 19th 2008
I only lost 4 pounds - but I didn't really have much weight to lose so I was drinking ensure and shakes all day long (with peanut butter, bananas, etc). I really fought to keep the weight loss moderate. I gained about half that weight back (so far, it's been only 3 months).
Oh, and I also was not wired shut, and wasn't too numb so I was drinking out of a cup immediately - makes a HUGE difference in weight loss, I'm sure.
I'm on day 13
And still down about 10 lbs. I'm telling you-- I am SO SICK of the liquid diet !! This seriously sucks !
megankaz,
I lost about 10 pounds after SARPE/MSDO. I still haven't gained it all back, and I attribute that to the fact that I don't snack between meals any more because 1) I can't eat crunchy snack foods, and 2) I don't want to have to brush.
If you are having trouble with weight, I highly suggest a protein powder or a mass gain powder from GNC. I know some of these are not the most tasty of items, but they should at least allow you to stop losing weight and stabilize until you can start getting more calories.
I will also throw out there that you can blend anything. I thought it would be gross, but I promise you there are some good blender meals out there!
-Chicago29
-Chicago29
protein powders are great. I managed to find some really good tasting ones. you can mix them into virutally anything to. My mom was mixing them into milk shakes and everything i was eating. WEll I did loose 9 pounds I'm convinced that it was because of the bad reaction to the antibotic because i couldn't keep anything in for a little while in the very beginning so I think that when i lost the bulk of the weight that I did.
The name of the protein powder slips my mind right now but I will ask my mom tomorrow for the name and will get back to you.
ensure is really good as well
