Misplaced midline after jaw surgery?
- vincejawsurgery
I just noticed that the midline of my teeth are still not in line with the rest of my face. My surgeon did mention it and said it was about 3 mm off.
Did this happen to anyone after surgery and how did the doctors correct this? I am thinking they will fix this with braces.
Vince's Maxillofacial Surgery -> My blog
- vincejawsurgery
May I ask, how long did it take to correct the position of the teeth?
My midline was perfect right after surgery and a week after being unwired it shifted a few mm. I was in elastics for a couple weeks with the OS and it was corrected. Again, a few weeks later the midline shifted and my ortho has me back in elastics to correct it. I am not sure how long it will take to correct the issue.
Upper segment and lower jaw advancement on June 23, 2010.
- vincejawsurgery
That sounds scary. I hope mine can be corrected without a lot of drama.mountaingirl wrote:My midline was perfect right after surgery and a week after being unwired it shifted a few mm. I was in elastics for a couple weeks with the OS and it was corrected. Again, a few weeks later the midline shifted and my ortho has me back in elastics to correct it. I am not sure how long it will take to correct the issue.
It's more annoying than anything else because elastics are such a pain. It doesn't bother me too much if my midline is off a few mm as long as my TMJ issues don't persist or get worse. That would defeat the whole purpose of why I had the surgery. They seem to want it corrected though.
I already know my midline will be off after surgery. I don't think it is worth getting my lower jaw done for about 2-3 mm of an off midline only. I don't know if the ortho will try to correct it with elastics, but he did put the little elastic loops on during my last visit.
RPE in on Jan 7, 2008
SARPE on Jan 11, 2008 expanded 7 mm
RPE out on May 14, 2008
