I am 7 weeks post op. I had a double jaw surgery and my teeth were wired shut for 5 weeks +. 2 weeks after I was debanded, I went to visit my ortho and he told me he was disappointed that I still cannot open wide enough.
I can make about 1.5 of the width of my index finger between my teeth. 2 weeks ago, I struggled to insert my last finger in between my teeth. There is definitely an improvement and I feel my jaw muscles can chew better now.
I feel quite insulted by my orthodontist because he expected me to be able to insert 2 fingers in between my teeth within 2 weeks but that didn't happen. He told me to practice opening my mouth as wide as possible whenever I can but I didn't do it because my oral/maxillofacial surgeon didn't mention I needed to do that.
I thought my jaws will recover in time just by using it regularly. I am personally quite happy with the speed of my recovery and I don't see why my ortho could not tweak the braces and remove the surgical hooks.
Is this normal? Did your ortho do the same thing? I am puzzled and I am thinking of looking for another dentist, which will be my 4th dentist during my whole process of correcting my jaw.
Vince's Maxillofacial Surgery
Post-Surgery: Ortho expects me to open wider in just 2 weeks
- vincejawsurgery
After only two weeks, it's odd to me that the orthodontist expected a better range of motion. If he does a lot of surgical orthodontics, he may have a good feel for where a patient's ROM should be, but I think the surgeon should be the one to make any judgements. Ask the surgeon if/when he will have you start jaw exercises. If I recall correctly, my ROM was pretty limited at two weeks, and I only had my low jaw moved.
As for tweaking your braces, I would not push it until all is healed well enough to withstand the pressure, especially if you do not have plates and/or screws. I speak from my own experience. The dental techs were pretty rough, and this may have been a contributing factor to my jaw not healing.
Oh and about the tweaking of the braces, when I saw my ortho she told me she doesn't want to adjust them for 2 more months so that a lot of the soreness from the surgery goes away before she goes back to moving my teeth and having that soreness. She didn't take out my hooks either, but I have been wearing rubber bands around them that I have to wear every day.
