Just a short question: if one has a 5mm Lefort impaction and 1.5mm advancement, and an initial gummy smile of 3-5mm, then how much gum show could be expected after surgery and what are the usual time frame for changes to occur?
I was in a rather naive belief that the bone and soft tissue movement ratio is 1:1, didn't even ask the surgeon about it. So if I have 5mm gum show and a 5mm impaction, then 0mm gum show should be the result. Apparently, it isn't
In a google book called "Oral and Maxillofacial Surgery: Orthognathic surgery" by Raymond J. Fonseca, I've found that the upper lip usually moves with about 50% of the hard tissue (bone) movement (page 486), altough he doesn't mention time frames. So this is basically the result I've had but still confuses me to no end, because I've seen here and at other sites some really convincing before-after photos where the gum show was completely eliminated. I think an advancement of 1.5mm is just not big enough to mess up the results of the impaction so much. Or is it?
What are your experiences?
Thanks,g
