Crowns & posts before or after sarpe?
manderin
#1 Post by manderin »
So if you get a root canal should you get it posted and crowned before or after SARPE? Same question in regards to molar implants. Before or after?
SARPE widens the palate and creates more space between the teeth so putting a tooth implant or crown post in before SARPE means you'll probably have to redo the implant or crown again later doesn't it?
