Did your lips change after surgery?
Leebie3
#1 Post by Leebie3 »
Just wondering if anyone has noticed their lips change in shape and/or fullness?
38yr old Mum to 3 (2 teens and a preppie) living in paradise with her man. BSSO surgery approx late April 2014!
survenant
Re: Did your lips change after surgery?
#2 Post by survenant »
My lower lip has changed a lot. I used to a have "large" lower lip. Now it looks more normal. My lower lip is now further in my mouth (don't know if that makes sense) so basically it looks smaller.
survenant
#3 Post by survenant »
Just to clarify, once the swelling has gone down, the "volume" of my lower lip stayed the same, it's just that the position has changed a lot which gives it a smaller look.
Leebie3
#4 Post by Leebie3 »
was that for under or over bite?
survenant
#5 Post by survenant »
underbite + long face syndrome + gummy smile.
I suppose that it could be different for everyone..
Anastasia8
#6 Post by Anastasia8 »
Upper jaw was advanced (too much), lip got bigger.
bmueller
#7 Post by bmueller »
Upper jaw moved up and forward, fuller more visible upper lip (from being bumped out).
Alicia110613
#8 Post by Alicia110613 »
My lower lip now appear smaller after mansibupar setback to correct underbite. Your lips are supported by your teeth so if your jaw moves forward or back, it will look different for sure.
kimnmoody
#9 Post by kimnmoody »
Same as bmueller, upper jaw moved up and forward. My top lip is more prominent now, in a good way. Looks much better than before.
Leebie3
#10 Post by Leebie3 »
hmmm I'm only having lower surgery now but I'm hoping it doesn't make my upper lip thinner.. it's already quite thin.. especially when I smile :s
