How much did yours cost???
JPs
cost
#46 Post by JPs »
I had to pay $5800 BEFORE they ordered them. They told me my satisfaction was guaranteed and they'd do it until I was satisfied. Also I'd be given whitening stuff to use in my trays at the end. Refinements were never mentioned - I learned about them reading websites, but I am assuming that's what they meant by doing treatment until I was satisfied. BTW - what's IPR?
22U 40L
Wildewoman
#47 Post by Wildewoman »
$ 6,000.00 here in CA. My insurance paid $ 1000.00 up front. My orthodonist is letting me use my flex spending from work - so I paid some in 2008 & will pay off the balance in 2009.
This is for 15 months of treatment - all the trays, x-rays, follow up appointments, etc.
Linda
TakingThePlunge
#48 Post by TakingThePlunge »
$3700.00 for Invisalign Express - 5 month treatment.
Simon D
#49 Post by Simon D »
Hello,
I've just found this board and registered as I start Invisalign next week (10/02). I'm based in the UK and my treatment is costing £5000. This included the inital consultation, clincheck, 26U/20L trays and any refinements I may need as well. Judging by the other posts, I think this is probably quite expensive, but I really liked the ortho and would rather pay a bit more to get someone who really knows that they're doing.
Simon
Alex2411
Re: Invisalign
#50 Post by Alex2411 »
irriatitedbybraces wrote:Does anyone know whether or not invisalign is able to pull teeth back? A
yes sure invisalign can fix an overbite
Braces On Teeth << My Invisalign Adventure
jjrp434
Cost
#51 Post by jjrp434 »
From my experience, the cost of Invisalign will depend on whether a dentist or orthodontist will be doing it. Orthos usually charge a little (sometimes a lot) more. In addition, if your teeth are really messed up, you may need to be in braces for a short time after Invisalign. Here's a site that seems pretty unbiased. There's information about http://www.bracesquestions.com/static/i ... ign%20Cost here. I think it may help. Good luck!
jjrp434
Cost
#52 Post by jjrp434 »
From my experience, the cost of Invisalign will depend on whether a dentist or orthodontist will be doing it. Orthos usually charge a little (sometimes a lot) more. In addition, if your teeth are really messed up, you may need to be in braces for a short time after Invisalign. Here's a site that seems pretty unbiased. There's information about Invisalign Cost here. I think it may help. Good luck!
