I've been unhappy with my top teeth for a couple of years - mainly because despite extensive orthodontics during my teens (4 extractions, 2 years metal braces, 2 years retainers) they are becoming increasingly crooked (I'm 26 now).
I've found myself a great orthodontist and have spent a couple of months getting them shaved to create more room. Had an appt yesterday and all's going fine and that my smile will improve but he thinks that really the only way to fix my crooked bite properly would be a ceramic brace. He says we can go for clear aligners but that that will take longer and that although there'll be an improvement in my smile, the bite won't be perfect. Price is the same either way and I have a month to decide. Fixed brace would be on for 5 months.
The other option is to carry on with the clear ones and opt for ceramic braces if necessary at a later date but that is likely to prolong treatment.
I'm actually really only concerned about 2 crooked teeth - the rest are fairly even (I wasn't aware I had such a bad bite til they did the molds!) Fixed braces seem such a trauma to go through when clear aligners will probably improve those two teeth - or should I go for it and get my bite sorted once and for all?
Thing is, I hated having braces as a teenager and don't have much self confidence so I really don't know if I could cope with a fixed brace. I have a big smile so not much chance of hiding it. I have a supportive boyfriend but I just don't know if I can bear fixed braces at the age of 26!
Are clear aligners really invisible?? And how noticable are ceramic braces? (mine would just be for the top jaw).
I'd love to hear from people (particularly those in the UK) - I read Florencegal's string on this forum and really empathised with several of you!
Thanks very much
