clincheck question
missmolly
clincheck question
#1 Post by missmolly »
does anyone know if you can view your clincheck on the invisalign website? someone told me you can...they said to go where it says im a patient and fill out the info...i did that but when i try to submit it it will not let me...the submit button you are supposed to click on does not light up..so you cant click on it has anyone else tried this and had the same problem? do you know if it even possible to view your clincheck on this website? thanks to any replies...
sarahr10
#2 Post by sarahr10 »
As far as I know, no you cannot view your clincheck online. The "Im a patient" tab is really for referrals (and a bonus check thing you get if you refer people to Invisalign)
I wish you could see it online though, that would be an awesome feature to add in the future! :D
Ewok2000
#3 Post by Ewok2000 »
I can watch my clincheck online through my orthodontists website.
