OWIE! My new aligner (#7 of 29) is sharp on the edges!!
My new aligner I just put in last night is sharp on the edges, and it's tearing up my tongue. I finally had to take it out to get some relief. Is there anything I can do, such as file the plastic down, or wax or something to help?
That happens me every so often too. One or two as my teeth moved I no longer felt it sharp as my teeth obviously moved a little and the aligner wasn't in the same position. One was so bad I had to file a it a little and the relief was huge. I'm not sure if it affects anything but I'm over half way through now and the ortho is very happy with my results
13 Upper & 11Lower
Start date 18 June 2008
Dental wax is your friend
I use dental wax, till i can get home and file the sharp edges.
I always keep some in my bag.
Jonathan
Jonathan
