Having trouble for the last few sets
So I was on tray 16 of 21 on my upper teeth before I last went in to see my orthodontist. He was happy, popped in tray 17 and gave me 18 and 19.... said he'll see me in 6 weeks.
Now I've been wearing them as normal, but the lateral incisor (the ones next to the two front teeth) is the one that I need to rotate so is quite problematic. I have an attachment on there and with the first set that he put in, I didn't think it was clicking in properly. I continued with the two weeks per set, now on 19 and it doesn't really fit at all. The weird thing is, I've kept all the trays and I can put most of them on and they all seem to fit the same...
Not sure if I'm being paranoid and that attachment isn't meant to fit snugly inside the brace or not. I'm just really concerned as I've only got two more trays after this one and my tooth doesn't seem to be anywhere near where it should be.
This is the before and after I'm supposed to have: roll your mouse on and off the picture to see the before and after.
http://www.freshfilmprod.com/view/teeth
If your tooth is still pretty far off this late in your sets of trays, it is likely that you will need refinements. I have had similar movements needed and am on my second to last tray. All looks good and there has been a lot of movement - but it is not yet perfect. I fully plan to have refinements. Disappointing, but it's okay as I am looking forward to the best results possible.
I had the same problem. I was almost finished with my trays but wasn't very happy with the results. I had to wear 8 sets of refinements and they brought the results I wanted. So don't worry too much, refinements are additional trays , you just wear Invisalign for a bit longer than planned.
started invisalign 23rd March 2009
finished invisalign 3 June 2010
Hmm... I know with Invisalign Express, there are no refinements included, but Full Invisalign includes three series of refinements. I suspect that varies from country to country, though, so maybe it is best to look at your contract with the ortho or give the office a call to clarify what is included in your treatment.
It really isn't unusual at all to have refinements, so please don't be discouraged!
Re: Having trouble for the last few sets
Turns out my refinement trays were included... all done now and onto the retainer.
