Mid-course refinements & brace has broken in hal, HELP!
cocoloves
#1 Post by cocoloves »
Ive had my current aligner in for over two weeks now and I had impressions taken a few days ago for mid-course refinements.
I have to wait for the new aligners to come in- could take weeks - and my aligner has just literally snapped in half where my incisor is! I dont know what to do.
Surely I cant carry on wearing a broken brace for the next 4 weeks but if I wear the previous/next aligner, the refinements wont fit properly!
Has this happened to anyone else? What should I do??
sammywantstraightteeth
#2 Post by sammywantstraightteeth »
You should talk to your ortho as soon as possible. I predict that the ortho would say to wear your previous aligner, and re-order the broken one.
Then you would wear your replacement for 2 weeks before starting on your new refinements.
Alternatively s/he might say its fine to go from your previous aligner to the first refinement - it depends on the treatment plan.
You must speak to your ortho as soon as possible - only s/he knows what is best for your treatment to succeed at this point. The longer you wait with broken or no aligner in, the more off-course you will go.
Treatment started: 13th July 2010.
http://sammiesbraces.livejournal.com
http://pics.livejournal.com/sammiesbraces
Expected finish: 14th June 2011.
Upper Trays: 21
Lower Trays: 24
