February Braces Poll
I was given 2 options to fix my 15mm overjet. Braces on top teeth only to bring my top teeth in by 5mm (a cosmetic solution), or full braces and surgery to correct my functional problems of worn teeth caused by a bad bite, periodontal recession and overcrowding. I went the surgery route and came out with a great functional result with my cosmetic improvements of no more gummy smile, a shorter face and improved profile.
I had 2 extractions prior to getting my braces, and 25 1/2 months later had upper jaw surgery (4mm up and out) with a cant in my upper right jaw levelled, lower jaw surgery (9mm out) and genioplasty (6mm) to correct my 15mm overjet.
5 1/2 months later my braces came off, so I am now 18 months post-surgery and just over 1 year out of braces.
Im having lower jaw advancement (11th feb
) and the removal of 4 wisdom teeth and an extra upper molar.
Feb Braces Poll
I had my 3 wisdom teeth (only had 3) removed over 10 years ago (had nothing to do with braces). The only applicances I have required were elastics to close my bite.
I've been lucky - my treatment is only scheduled to last about 8 months, which will hopefully means I'm done in about 1 1/2 months!!!!!
First time in braces, extraction of 2 upper pre-molars (one each side) as part of treatment to reduce over-jet. Open-bite and arch discrepancy went unnoticed and untreated. Over-jet remained after treatment. Later, unrelated extraction of 2 partially impacted lower wisdom teeth.
Second time in braces. 2 options. Surgery to advance lower jaw but no extractions, or no surgery but extraction of 2 upper first molars (one each side) and en-masse retraction of upper incisors, canines and pre-molars. Decided on extractions option.
Upper wisdom teeth through, so after treatment will be left with 1 pre-molar, and 2 molars on each side of upper jaw and 2 pre-molars and 2 molars on each side of lower jaw. Suspect crowding in lower jaw may lead to extraction of a pre-molar on each side, but has not yet been suggested.
February Brace Poll
Hello all ~ my first post and I am very happy to find this site! My braces went on Jan 28th (full metal bottom/clear on top front four) after almost 20 years of 'thinking about it' and two kids' braces later. I am scheduled to have four teeth extracted on February 26th (yes, he is known for extractions Post braces). The four teeth being removed are simply not 'bracketed' (is that a word?) Fourth back in each quadrant. Same diagnosis I received when I was 19 and then backed out. (glad I didn't this time)
4 extractions
I just had 4 extractions yesterday. 2 upper wisdom teeth and 2 upper 1st biscuspids. No pain. I will get my braces on March 4th.
Ouch
When i was 13 and was exmined for braces, that ortho told me all 4 wisdom teeth and all four biscupids!
My mom decided to wait and I never got them. At 25 I went to the ortho and he told me the same thing. I was hoping that mouth had grown some.
Well I had all four wisdoms removed! OUCH! And this past Valentines day I had all four first bicuspids removed. I still don't get my braces for another two weeks though. Right now I have in spacers and I get T-Arch put in Monday. I'm just looking forward to the end result
Fairly certain I will need a frenectomy. Just seems like too much tissue to get squeezed around.
And I will be needing to get my wisdom teeth out once they errupt. Hopefully before they wreck the work my braces will do.
My Invisalign blog ~>http://upsanddownsintheothersideofthest ... gspot.com/
No extractions this time, but after I had my braces removed 25 years ago, my ortho said that I would need to have my wisdom teeth pulled because I had no room for them. So when they finally came in five years later, all four came impacted and needed to be removed.
B
B
