is there anyone here who tryed this? My gummy smile is due to a deep overbite and diastema. I was wondering if there are any diaries here about using tads to fix overbites/gummy smiles (with pictures).
I've already tried to find them, but there are many diaries and some of them doesn't have pictures or aren't complete. So please help me. Thanks.
miniscrew implants/tads to fix a 4 mm gummy smile
Re: miniscrew implants/tads to fix a 4 mm gummy smile
I had TAD's in for my whole braced time and the link to my story is in my signature. If you do a search you will find a couple other stories also.
I saw your other post that you had de-braced, congratulation !
Did you fix your gummy smile with tads? My ortho suggested to me during my last adjustment.
Hi, I didnt really have a gummy smile. I had an overjet of 11mm (I think) and it was fixed completley with the TAD's.
