Had my top braces fitted Sept 28th 2006 and will have the bottom ones fitted on the Jan 2nd 2007. Great way to start the year!
I have ceramics on the top and will have metal on the bottom.
I am amazed at the change that I can see already with my teeth. Funnily enough, I didn't get braces because my teeth are crooked - which they are- but because I have a missing tooth in the lower teeth and my teeth are moving across and back.
When I first had the braces fitted I wondered if I had done the right thing because my crooked teeth had never really worried me and they were part of my identity. Now that I can see the changes happening already I am really excited about the prospect of having straight teeth.
My ortho suggested a time frame of 24 months but I think it may take longer than that as he was going to put my lower braces on at my last visit but decided to put it off until Jan. That was a bit disappointing but I am resigned to the prospect of turning 50 and still being braced.
I have gained a lot of useful information from this site - so thanks for that.
Code: Select all
[list][/list]
