hey guys...
Im going to be getting braces put in on the 8th of may. went to a dentist earlier in the year for a check-up n had some fillings done.asked him about braces too coz i have a rotated upper incisor n otherwise my bottom teeth need to be straightened. so he said he would do it..he not referring me to an orthodontist
is this common tho? anyway, im getting full metal coz he said that ceramics would be R2500 more n my medical aid wudnt cover it.. n also iv read here that it stains quite easily and takes longer..
my treatment plan is looking at 9-12 months, im very self conscious about getting them, i havnt had them before but its great to have found this website, i feel much better knowing im not the only one and evryone seems so friendly n motivating [/b]
!!! BRACES 2 DAYS AFTER MY 21st !!
same bday
Hey, we're getting braces on the same day...
Re: same bday
[quote="e^jtheta"]Hey, we're getting braces on the same day...
hehe kewl r u jus as nervous as i am? what work r u getting done and for how long? strange that we half way across the world from each other but we are in a similar situation
New Braces....
I have my bottoms on and my tops will be ceramic ones which are clear so as they do not show as much as metal ones do. I like KK know there are some ligs that stain but most not too bad! good luck!
"To error is human, to forgive is divine."
- jennielee81
I had 6 ceramics and they didn't stain. This is, as KK said, the fact. I never had ligs on mine so I didn't even have the illusion of staining. I can assure you, the material ceramic brackets are made from is not prone to staining!No ... ceramic brackets don't stain. I've got four of them ... and I eat spicy curry with haldi (tumeric) powder, at least three times a week, and they're the same colour as the day they were put on my teeth. Some coloured ligs can stain ... for example I turned blue ligs green after one curry ... but they're the same ligs that are used on stainless brackets.
I wish you well in your treatment and all! 9-12 months doesn't sound bad!! I had mine for 21 months...belive me, once you've gotten used to having them, the time doesn't really seem that bad! Oh!! and the outcome is completely worth it!!
Good luck!!
