Update again
I had my second adjustment today
Thought it was going to go terribly wrong as I am full of cold and had a massive coughing fit like 5 minutes before hand
Luckily though got in there, sat down. First I questioned about my midline on the top being off, she said it was normal to notice little things like that. But then we I lay down and she had a proper look she is thinking otherwise. Well she took the wires and ligs off anyways
Then put some slighter thickers ones on
I decided to go with a light blue ligatures this time
But we have discussed the whole midline problem and we decided later on down the line if elastics don't bring it into line that I could have to have 2 more teeth removed to make room -,- She has said she will look at my case study to see :/ But hoping at next adjustment to know more
Weirdly enough pain wise isn't too bad
Just a tad sensitive, although I had a glass of milk and it seemed to make the wire contract XD Strange times :L
11/11/10 - Got Braces (Top and Bottom) -
Green Ligs
21/12/10 - First Adjustment -
Bright Pink Ligs
01/02/11 - Second Adjustment - New Wire -
Bright Blue Ligs
15/03/11 - Got Elastics 6.4mm to twist twice on both sides
10/05/11 - Got Power Chains and elastics both sides
21/06/11 - Power Chains on bottom, elastics on right hand side
