Waterpik yes or no?
Waterpik yes or no?
Ive been told by several people that I should invest in a waterpik. To me it doesnt seem like it would get iin between teeth clean as well as flossing... Anywho, I wanted to get other peoples take on it. How well does it work, is there a specific type, where to buy them?
Thanks Katie
Thanks Katie
Re: Waterpik yes or no?
I was wondering too!
Seems as no one wants to answer hahaha. I think im going to purchasreone and see how well it works.
I have 2 and it's the best thing I have for cleaning...I have a base unit, and a portable.
My old teeth are very close together, I still have all 32, so flossing has been an issue, as
the braces align my teeth, slowly, I am able to floss, but I have always been able to use the waterpik......It does a good job for my teeth. Also use the GUM trees, their great.
Oldguy
Oldguy
Thank you so much for your feed back!
- sablequeenie
Can't recommend a Waterpik enough; you'd be surprised how powerful a flosser water can be. My orthodontist recommended one to me and even after I use normal floss, I can still see the difference the waterpik does just in making my teeth feel squeaky clean around the brackets, especially after I've used the brush attachment.
Thank you so much, im definitely going to purchase one!
They're definitely worth it. I use mine before and after I floss, and it's always getting stuff out that I would have otherwise missed.
I wouldn't use it as a replacement for floss, but it's a great supplement.
I want to buy one too please let me know how it goess and where you bought itkgallagher wrote:Ive been told by several people that I should invest in a waterpik. To me it doesnt seem like it would get iin between teeth clean as well as flossing... Anywho, I wanted to get other peoples take on it. How well does it work, is there a specific type, where to buy them?
Thanks Katie
I can't imagine having braces without one! It helps tremendously in power washing the leftovers from between the wire and teeth/brackets. Once I finish pressure washing my teeth I brush, then floss, then rinse. It's a great combo- my ortho calls me his most compliant patient.
50 year old kid at heart
My story:
http://www.archwired.com/phpbb2/viewtop ... =9&t=44406
Debraced 2/25/14 WOOOOOOOHOOOOOOOOO!!!!!!!!
My story:
I'm going to buy one today actually! The one I want (Ultra) is only like $45, so why not.
Im going to get mine this weekend!
I bought the Waterpik Cordless Plus from Target. I want to say it was about $39.00.
Holy smokes, this thing is great. I bought it a few days before I got my braces and even then, it got out so much gunk that you wouldn't think was still there. Now that I have braces, I don't know how I could live without it. It goes everywhere with me. Mine came with two regular rinse tips, one plaque seeker tip, and one orthodontic head. The the plaque seeker tip has little bristles that are great for really getting in between those braces!
Just a word of advice, make sure to keep your mouth closed or you'll get water all over the place trying to see how it works!
Hmm I bought the ultra this weekend. Should I have gotten the portable instead?
I just bought mine and I love it. I went and bought my husband one even though he doesn't have braces.
