I found out after getting braces that I chew on the right side of my mouth.
It was something I had never thought about before.
Which side of your mouth do you chew on?
Re: Which side of your mouth do you chew on?
Left side when they're sore. Right side normally
I am chewing on my right side - purposefully. I have a power chain on two molars trying to turn them on the left side and EVERY little bit of food gets stuck under that if I chew over there at all!
Pre-braces, I always chewed on the left side, so I still do it out of habit sometimes, but it doesn't take me long to remember why I don't chew on that side.
right side for the longest time until my extraction hole on the left closed and the right wasnt budging....sure enough when I switched sides both holes closed.
Used to be my left side but now with these build ups in I kind of use both. Feels pretty odd.
Left side...Does anyone really use their front teeth to chew? I don't but never thought about it until I realized that after tomorrow, I might miss being able to use them.
