Ok so I had a tooth removed on the bottom on 3/21 and braces placed the same day (that was FUN!) and here is two month progress!
I think I can tell more of a difference because they are my teeth, but wow. I am super impressed. Also, let this be a disclaimer that up-close photos of my mouth are not at all flattering.
Exactly 2 months in ... (pics)
Re: Exactly 2 months in ... (pics)
Yea that is progress for sure!! You are certainly on your way.
carrieann wrote:Yea that is progress for sure!! You are certainly on your way.
Thank you! It's exciting.
I have to get teeth extracted but my orthodontic is placing the braces first. She will be removing premolars so they won't be banded yet anyway. I hope it doesn't take long for the gaps to close.
[quote="Snoopy41"]I have to get teeth extracted but my orthodontist is placing the braces first. She will be removing premolars so they won't be banded yet anyway. I hope it doesn't take long for the gaps to close.[/quote]
