Is Invisalign Appropriate?
Locked
CrookedSam
#1 Post by CrookedSam »
I just had a consultation with my dentist re: Invisalign and he said he did not think they would work because I may have TMJ. I don't think I'd need a great deal of adjustment: I have crooked teeth in the front on top and bottom (5 on top and 5 on bottom). Have you had a similar situation? Should I get a second opinion? Also, how successful is Invisalign vs. Lingual braces? My dentist did not tell me about linguals, just "conventional braces".
DrJeffOrtho
#2 Post by DrJeffOrtho »
Putting the Invisalign plastic between the teeth can aggrevate TMJ problems, it can also allow the jaw to reposition to a more biologic position of the ball in the socket - but this physiologic repositioning of the jaw can make fitting the teeth together with Invisalign more difficult, if not impossible. I don't recommend Invsalign to my patients with TMJ issues.
Lingual braces can be effective, however they are not for beginners - they are more complicated and also less comfortable, at least at first.
Find an orthodontist and check with him or her about what would work best for you.
Locked
