clear permanent retainer ????
Locked
leah
#1 Post by leah »
I will be getting a clear fiberglass permanent retainer for my bottom teeth. and maybe the top too. I was wondering since I'd never heard of this before if you could explain what the differences embetween this and the normal metal. And pro's and con's...
Thank you for any replys
Leah
lower wisdom teeth cut out 1/27/05 (ouch)
braced 3/8/05.
24-30 month Est.
going full metal 8/22/05
Naked as of August 28, 2006
DrJeffOrtho
#2 Post by DrJeffOrtho »
Orthodontists are always looking for materials that are easily adaptable to the contours of the tooth yet strong enough to withstand normal biting and chewing forces, flossing, etc for bonded fixed retainers. I hesitate to call them permanent, because thay can break, or even come out.
However, the difference between the clear fiberglass retainer & metal is just the difference in the materials. As long as it contours well to the teeth, stays in place, and can be easily cleaned, it doesn't matter what it's made of.
Locked
