I know that when your gums bleed when you brush that usually means you have a gum disease. However, I've never had this problem until my last adjustment. I was given a new thicker wire and also those rubber bands in the figure eight shape that connect to two of my teeth to close gaps. This just started recently, and I've never had a past history of gum disease or anything. I use listerine twice daily and brush twice daily.
Is it normal that the movement of teeth from braces can cause your gums to be weaker and bleed more when you brush? Is this normal?
Thanks.
Normal for gums to bleed when brushing with braces?
- Location: Australia, , braced on 8 MAR '05 - Debraced: 28th FEB '07
maybe you had a minor infection. maybe it was a bit of food stuck in your teeth and braces that caused it to bleed. and u could ahve brushed and cleaned it away.
Nahhs, Jaw Surgery 'n all<
Progress Pictures on Pages 1, 2, 3, 4, 5, 10, 11, 12, 13 Debracing/Teeth Whitening Pictures on Pg 16
Lower JAW Surgery: May 2006 Debraced: March 2007
Sometimes my gums bleed, I think it's just that they are under a lot of stress from the movement of the teeth and they are kind of stretched thin...at least that's what I've always hoped. I think also when you try to get between your braces and the gums it's hard to brush it without brushing your gums as well so that may lead to bleeding
Eve
Eve
Braced September 9, 2002
Debanding: JULY 5!!!!!!!!
I agree with all of you. I remember one of my ortho's assistants telling me that if you gums bleed, brush them harder, to get rid of any infection...I thought that was kind of weird but then again maybe it would help!
