What does a T-Bar do?
Locked
TuZZi
#1 Post by TuZZi »
A T-Bar, that's what my ortho called it, but it doesn't look at all like a T. I'm guessing the T is short for something?? Anyways, the bar goes from my upper molar bands across my palate, and just sits there. I had extractions right beside my molars done last week, so I'm guessing it's some kind of an anchor to keep those molars in place?
I will include a picture later... but now I have to go back to work.
Full On Metal! Aug 31, 2005
Infamy
#2 Post by Infamy »
It's likely a Transpalatal arch.
Does it look similar to this? http://www.fine.com.au/images/transpalatal.jpg
Formerly known as Jim
ricardo2
#3 Post by ricardo2 »
...Sounds like a nance/ TPA. I've got mine to stop the back teeth moving in to the space for my canines to come down in to.
They are a pain in the bum to clean! :(
Recent posts about them:
viewtopic.php?t=6559
Take care
LUCY xxx
TuZZi
#4 Post by TuZZi »
Infamy wrote:It's likely a Transpalatal arch.
Yep, that's almost exactly what it looks like.
And yes, it's a pain in the butt to clean. I ended up hitting my front teeth multiple times tonight when I was trying to brush it. Boy, was I NOT a happy camper after that!
Locked
