Elastics question?
Elastics question?
I have been wearing my braces for 2 1/2 months now and at the beginning of this month I started wearing rubberbands. They are in a triangle and connect with my first rubber band bracket hook on the top teeth( I don't know what to call it) and my first two on the bottom. My ortho said it was to stabilize my jaw. I do not wear them all the time like I am supposed to and was curious how big of an effect this may have? I probably wear them on an average of 20 hours a day.
I also wanted to ask another question why I am at it. My teeth are pretty much straight the reason for the braces is that my jaw because of a car wreck and growth moved into that wrong spot. The real problem is when I close my mouth my teeth do not meet properly and I am left with openings. Is there anyway to move my jaw into the proper place without the braces? What are some alternatives that I might be able to mention to my orthodontist next time I see him?
jaw
If your jaw is in the wrong location and biting improperly sometimes jaw surgery is the answer for the ideal result. Likely your doc is trying to compensate for poor jaw position with getting the teeth to come together more ideally. A camoflouge (sp?) if you will. Pound for pound any orthodontist would rather treat teeth that are crooked and jaws that are in good harmony than the opposite. Good Luck.
Raleigh, huh? What's up with Coach Amato and The Wolfpack?
Dr.J
go SC ocean!
Dr.J
go SC ocean!
Dr.J - Ortho
Curious about your answer
Dr. J,
I am curious about your answer. Like Paul, I have very straight teeth, but I am getting braces due to poor occlusion, an inconsistent bite and a possible Class 3 jaw alignment emerging. I also suffer from chronic morning headaches and TMJ. My front teeth do not touch (there is a large gap) and I have tons of pressure on my back teeth. The gap has gotten wider over the past year or so.
I was told by my dentist and ortho that it is better to get the braces now than to wait and "have to" get jaw surgery to make my teeth come together and fix my alignment and occlusion (and possible future class 3 scenario). Your response below makes it seem like braces are just masking the problem, rather than correcting it.
Are you suggesting that jaw surgery is a better and easier fix than braces?
jaw stuff
Without access to your records its tough to say what the right answer is. Most orthodontists are very careful not to say that treatment with braces will ever cure a TMJ problem or headaches. This is counter to all the evidence in the literature. Very shaky ground if you will. If you have a jaw problem and it's corrected with tooth movement you must accept that this is a compromise and you may not feel better at all. You may feel worse. The only thing predictable about situations like yours is that they are unpredictable when the surgical option is not considered. With your symptoms I would get one if not 2 more opinions from orthodontists regarding your need or lack of need for jaw surgery.
Got any pics? Does your jaw click and pop? Muscle pain? Ever had a jaw locking episode? History of trauma? You indicated the situation is worsening over time - perhaps an MRI of the joint would reveal a arthritic process that is totally independent of your teeth. These are things to consider. If a true class 3 jaw problem is "emerging" then it will continue to emerge after braces. Are you still growing? How old are you?
Dr.J
Dr.J
Dr.J - Ortho
Thanks for the response. Things with Chuck and the wolfpack are not going to well. It is hard for me to even talk about right now considering we just lost to Wake Forest a couple of hours ago. He is on the hotseat now but he will definately get another year and hopefully can turn things around. SC pulled out a close one today.
jrh, your problem sounds almost exactly like mine. I started suffering from TMJ and got a splint, my jaw moved and I was unable to touch my front teeth together. I have had my braces on now for 2 1/2 months and my top teeth go over my bottom teeth almost like they are supposed to now. Just this last week I started touching my front teeth together for the first tme in several months. I really havent noticed many changes in the TMJ stuff like headaches but my bite is still kind of off. My jaw has moved a ton though since I get my braces. I have found the best way to control the TMJ pain is to watch what you eat, eliminate caffeine, try to get good consistent sleep, and to put hot rags on the jaw muscle a couple of times a day. Hope this helps you.
