hooks and elastics
Locked
Whitney
hooks and elastics
#1 Post by Whitney »
I have ceramic uppers (on 4 crowns no less) and metal lowers. So far, so good. The metal lowers ALL have hooks on them. My bottoms are a bit crowded and I currently have two spacers. I am just wondering HOW and WHERE the elastics are going to go??? My otho never even mentioned it in my "findings report." Thank you!
weird_wired
#2 Post by weird_wired »
It will presumably vary depending on your specific requirements - you may not even need them at all. The "triangle" - which I have - seems to be quite a common configuration. But there are also multi-band, criss-cross configurations that people have.
Do you have any hooks on your upper brackets? Because that should indicate what - if anything - your ortho is planning to elastic.
Locked
