Hi Doc!
I've been having my elastics pop off at night-I check them before bed to make sure they're on right and they are on right-but when I get up in the middle of the night they've popped off!
I have a tricky elastic config. where I have to hook (hook looks like a butterfly) the elastic behind the eye teeth on top and then hook the elastic onto the front hooks of 2 bottom teeth (can't remember what they're called!).
Thanks!
Renee
elastics popping off at night while sleeping
Hi doc, just wanted to let you know I got an answer to this from my orth-he said they do pop off at night & that's normal. He joked & said as long as they don't pop off and fly at someone then I'm good to go. lol!
Renee![Very Happy :D](./images/smilies/icon_biggrin.gif)
Renee
